Cal Metal, I just went down to check and I realized the the original motor is not complete. It is missing pushrods, intake manifold, valve covers, and carb. I assume some of these parts were put on the motor that went into the car. Sorry about the mixup. The only number I could get to (underneath some tarps and cushions and other crap) was on the right passenger side fo the block, just below the head. It said L2056. I was reading the attatchment you sent me I rember that the motor in the car has the cast valve covers with corvette written on them (not sure if 9 or 7 fin though). I will check what it says on motor in the car and reply later. Thanks to all you for your help, your knowledge is very impressive.
2500 Pounds of steel, rubber, and fire. AAAHHHH!
