Thread: Carb Backfire
Old 12-09-2001, 09:19 PM
FIAFRED FIAFRED is offline
Don,
The rocker has a nut over a threaded shaft which holds the rocker in. In visually looking at the nut, and trying to turn the nut by hand, it was not loose, if that means anything. The rod is stamped with 8.750, and bent about 11/2" down from the top, where the rod is narrowed to seat under the retainer plate. Does this give you any more info that will help you direct me on how to go about instaling a new one?
Fred
