Old 11-14-2009, 06:18 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Default I've got a question for you?
Cobra-351 - everything is as expected-Carb'd.
PROBLEM: Engine will not start in cranking mode.
Solutions; New Solenoid- (has power with the key)
New Ignition switch- all contacts checked and working.
Push or Pull the car, pop it in gear and it Fires right up! ?
Yes, has an MSD 6, with matching Distributor- ALL checks-OK.
Engine STILL cranks over- but will not start, back to the push pull mode and it will fire right up.
What am I missing?
DV
