I would run a jumper from the hot wire going to the ignition switch to the wire to the ignition system. That will guarantee you have power to the ignition system. Hit the starter and see if it starts and runs. If it does, then either the switch is wired wrong or the switch is not working correctly.
Tommy
Previously owned EM Cobra
