Ron: are you saying that your kirkham has a csx wiring harness? don't know about the csx part, but my kirkham wiring dia. shows flasher output and brake lite power after pedal sw going to a "stop lamp isolating relay". I have no idea where it is located, but probably under the dash. All stop/turn bulbs run off the output of this relay. The dia shows only the front L&R turn bulbs, I assume the rears are just paralled off the fronts. I'm not set up to scan, but I could fax this page to you. Also, call kirkham, i'm sure they can help.
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
