One thing I forgot to mention, if you use the older style water pump, as I did, tell era if you are doing the plumbing as it requires a different style lower radiator hose routing than what is the "norm". Most folks use the newer style water pump which exits on the opposite side. Era has the hoses for both styles
live for the moment or it may pass you by
