Old 11-18-2009, 07:27 PM
patrickt patrickt is offline
Originally Posted by ng8264723 View Post
I used my snap on clutch alignment but it must have been off and I didn't try the tranny first. I put the engine in with the scattershield on. So now I have to align th clutch again.
That sounds strange. But, if you happen to have TKO600 behind an FE, the spline on the driven disk, with most clutch alignment tools, does not fit perfectly with the pilot bearing (because you're really using a Chevy driven disk and tool, but you've got a Ford pilot bearing). Mike Forte makes a tool that fits perfectly, though. That's the only way I could make sense of your clutch slipping out of alignment, either that or you have the wrong transmission.
