A trick I learned that works "most" of the time and saves some time- while someone is lining up the tranny and ready to slip it into the pilot bushing, have someone push in the clutch pedal so the disk can move a bit. Usually, if you are close with the tranny shaft nose, the loose clutch disk will let you make the final little adjustment and slip it in.
Bob
