  #23 (permalink)
Old 11-19-2009, 12:42 AM
COBRANIP COBRANIP is offline
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
On the Herb/Matt Adams Satchel (sp) Link the upper bars "point inwards". That is the mounting points on the axle are directly above lower bars mounting points but angle towards the transmission tunnel for the frame piviot/mounting points. Angle is 30 degrees from a line parallel to the center line of the car. (Axle mounting point wide; frame mounting point narrow.) No panhard bar or watts link.
Hope this helps.
