Old 12-10-2001, 03:30 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
Either your battery cables are too small (I always suggest 00 gage welding cable) or your ground is insufficient. Make sure that you main ground (the batt neg) is fully contacted--no paint, and to the frame (I have seen this cable run to the crossbar for the rollbar that had painted surfaces where it hit the frame!) and I would suggest running 2 ground straps (both 00) from the motor to the frame, and from a starter bolt to the frame. This is a redundant feature that will keep you from being stranded if one ground works loose!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
