Thanks Tom,
Not long at all.
I can achieve any A/F @ idle I want with the scews, but when I have it in a reasonable range 13.5-14.7 the cruise ( below 22-2300 ) will run as high as 16+. I keep tabs on the plugs & everything looks ok, pretty white but ok. As soon as I apply a little throttle it picks right up 13.5-14.5. The richer I run the idle the better the cruise is, But as you know there are limits to that.
Your mod--will it richen up & change the idle adjustments also, or will it just help out the transition?
I have 18000mi on the engine & get 22 MPG average.
Thanks again
Craig
