Well guys' I did it fixed the
oil leak, routed the coolant overflow differently and changed out the clutch master/slave. Ran the car to temp and the t-stat opened, but I forgot to close the overflow drain so we spilled more coolant on the floor. I found some more wire issues. But I still
TOOK IT FOR A SPIN :mf_w00t1::clap::thumbup1:
Now for the bad news fan relay power supply needs to be rerouted and my speedo is not working, it has good power. I think the signal is messed up, the sender is from the 03 t-3650 will that work with the autometer speedo or do I need the adapter.
Patrick
P.S. Thanks to Jerry for coming down in his car and keeping me sane while I did this.
