Old 12-10-2001, 09:47 PM
RobMcQuarie RobMcQuarie is offline
Default SVO Damper
The damper Ford SVO sells does interfere with the water pump, and you will have to clearance the pump. They used to state this in the catalog and in with the pump. You will also more than likely need a spacer for the damper to mount your pulleys. I don't know why Ford chose to carry a damper that needs so many "alterations" when there are equally good dampers available that are just straight bolt-ons. Typical of SVO, they probably were able to buy it at a lower price.
At least you mocked things up first, it won't take that much grinding to clearance the damper.
