Finish Line, Cobra Restorers, others. Most will fit standard carbs with dual feed lines no problem. You sometimes have to enlarge and shape the pan holes to accomodate a specific setup. For all but the biggest changes, a Dremel with a stack of sanding drums and a little patience and care will get you where you need to go.
= Si Opus Quadratum vis, angulos praecidere noli. =
