Originally Posted by CHANMADD
The brake/park light bulb is a double filamet bulb and the brake filament is brighter than the side light one ( in the same bulb) If you switch the fittins you still have the same problem!
I actually swapped the whole socket/unit so the brake light is now on top. The brake/running light in the top socket is now more visible and brighter. For some reason, the brightness of the turn signal in the lower socket seems to be on par with the standard configuration.
Doug
Reason: added comment
