11-28-2009, 09:43 PM
WA
Cobra Make, Engine: FFR MKII #3133 3:27 Pin Width IRS, Carb'd Explorer 302 w/GT40P Heads, 3550 Mid Shift, Power Brake Mod, 15" Torque Thrust D's
Latches coming along:
Bonding the hood.
I used spacers to get the hood to match the level of the front clip so I don't have to use so much Rage Gold (read less sanding!) I used the same structural epoxy that I bonded everything else with. (linked in an earlier post on this thread)
I drilled a lot of #40 holes about 1/16" deep around the edge of the hood, and a bunch of #20 holes around the edge of the hood opening about 1/16" deep. This thing isn't coming off.
I'll also use some glass cloth and resin underneath as well.
Time to break out the Rage again...
Doug
