Old 11-29-2009, 08:22 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
I had a machinist buddy of mine fabricate a small block of aluminum with offsetting holes. The holes on my heads would not allow a directly vertical mounting of the coil bracket. On the fabricated bracket, two holes aligned with the head holes, and two others were shifted to allow a direct vertical mounting of the coil. I used a MSD chrome bracket that came with the coil. I also used 1/2" offset cylinders over bolts to space the bracket away from the head to move it further from the head heat source.
Sure, not original, but it looks pretty cool.
DD
Dangerous Doug
"You're kidding, right?"
