49 hours into final build, 9 days down, 81 to go.
Only got enough time to trial fit a another way to connect the sway bar to the lower arms.
Check out the picture below, prior to final assembly I would tig weld these bolts together. this would keep heim joing close to u bracket. or i could take a piece of half inch thick by three inch plate steel and drill and tap it to move it directly over the u bracket. i think I like this approach better that extending the u bracket to the front. What are others thoughts.
so far the sway bar is still at completed ride heights, but lower arm is still not positioned to ride heighth.
http://farm3.static.flickr.com/2581/...794cdc87_b.jpg
http://farm3.static.flickr.com/2677/...924136c1_b.jpg
http://farm3.static.flickr.com/2612/...8e0927d4_b.jpg
http://farm3.static.flickr.com/2548/...38c114fd_b.jpg
