11-30-2009, 08:12 PM
ca
Originally Posted by RodgerH
Had the same problem on the first assembly of my engine (527" Shelby alum. block, Keith Craft Stage 3 ported Edelbrock alum. heads). Changed head gaskets....same problem. Finally milled the surface of the heads....only took a slight cut, maybe .010". Put it back together and all has been good. Apparently the heads were not absolutely flat from Edelbrock.
Rodger
I find it hard to believe Keith dose not mill the heads! when I recieved my Edelbrock's from summit the bottoms were very rough and had to milled.
Mike Z
