  #22 (permalink)
Old 12-01-2009, 07:20 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by twobjshelbys View Post
My tale is described in some detail elsewhere. I bought it at the Barrett Jackson auction in January. Alfredo did tell me that the previous owner had thought it was plagued with electrical problems and I do believe the FI control system is the cause of the rough running. I had it on a dyno and it was running real rich. The AFR matched from the Dyno and the FI controller, but it turned out to be TWO loose plug wires (as described above), so I'm replacing the 90* plug wires with 45* wires to keep tension off. We'll see. Sometimes it's simple things. It's definitely running rich - when I let off the accelerator I get small backfires from the pipes.
As for oil, it gives a little puff of smoke when it starts, but so does my new Mustang. I also think it might be one of the valve covers leaking but haven't gotten there. I agree about the dye kit. That's on the list. The engine takes 11+qts!
The dye kit works really well, but it doesn't always isolate the root cause. For example, I had a problem with a leaking oil galley plug and they ended up needing to pull the trans out to fix. I did isolate an oil leak on a valve cover gasket that was causing a mess.
Doug
