  #39 (permalink)
Old 12-02-2009, 08:35 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Why the heck worry about 8 quarts or 12 quarts,? If Roush wanted 12 quarts I sure would not spend several hundred dollars to reduce the system volume.
Ron, I understand you are waiting for custom pistons to be manufactured if got the correct jist. What overbore or how many thou over the stock or original bore are they going? I know they are the guru's but seems a sleeve in the damaged cylinder would keep you from having to over bore the engine. What is the latest info on when you can come play? She sure has a sweet sound and a great rumble coming down the road.
Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
