Or hit CTRL-+ to increase the size. (CTRL-- [that's CTRL MINUS] decreases size. CTRL-0 [zero] resets it to the default.)
I believe Firefox started holding display size by site a rev or two ago, so that if you scale up one site with teeny fonts, it will remain scaled while others display at the default. You might have accidentally scaled down the FF site on your last visit.
(EDIT: Yep, just tested it - reset the display on the FF forum with Ctrl-0 and you should be fine.)
= Si Opus Quadratum vis, angulos praecidere noli. =
