Old 12-12-2001, 09:17 AM
Bish Wheeler Bish Wheeler is offline
Cobra Make, Engine: A&C 427SC #188 ZZ4 Crate, Tremac 3550
Send a message via AIM to Bish Wheeler
Cobra Ed
In order to change to the 31 spline axles, I found out, you need to redo the the rear end. It requires a new carrier, which is the guts of the rear end and the 31 spline gears are contained therein. That unit costs $500. +/- and the axles go for around $200. per copy. It's not an inexpensive mod when you add in labor. However, from what I have discovered in this drill, the 28 spline, unhardened set up will eventually get you into trouble. In a way I was lucky, we found the problem before a breakdown. Zderf was out toolin' around when he busted his.
Vincent
Always the critic. Hey send me you e-mail address. I need to forward you something. I have been using the e-mail function here and I don't know how to or if you can fwd with it.
