Ball park wheel alignment specs?
Midstates Cobra running 235/60/15 front and 295/50/15 rear. Going to be changing entire suspension, adjusting "L" brackets, coil overs etc. Need spec's to start with then leave it to the alignment people to dial in. Currently, front coil overs (Qa1) have about one inch of shock threads exposed, rear have 3 plus inches exposed. When the rears were raised (previous owner) to clear tires, the front wheels started rubbing on the outside. Prior to jacking the rear there was no front tire rub. Any help with alignment spec's would be appreciated.
