Old 12-05-2009, 07:35 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Tim,
The battery information is on my Wiring Diagram. Did I mention that there will be a test 30 days after you purchased your copy?
I personally like the way the Interstate 58R fits.
Also, here is a neat trick:
At Sears, they have a generic expandable plastic battery hold-down. It's made to span the battery's short dimension, which is how batteries are usually secured. If you cut the "handle" sections off and use just the 2 end sections, they slip perfectly over the 2 cover mounting rods and they sit on the edges of the battery as if they were made for the car.
A little experimenting with those plastic nylon spacers from a hardware store (for the proper length) and the ferrules that secure the battery cover on also clamp tight up against the new battery mounting pieces you made and you are in business...Maybe a $3.00 project...and 15 mins.
Here is a photo of the work in progress, before I cleaned up the clip and added the nylon spacers..
Blas
SPFWiringDiagrams@Comcast.net
