First thing I checked was distributor installation and it was correct. If it were installed a tooth off, rotating the body (assumed there is enough clearance for tha vacuum canister) would still allow the timing to be set correctly. I've got a good Sun timing light and have double checked it with another one. I've connected to #1 plug and verified TDC and timing indicator 0 deg with a dial indicator. Mechanical advance works properly; timing advances smoothly as rpm increases.
