Originally Posted by elmariachi
There are no curves in south Texas so I can handle that.
Didn't have one yet anyway.
I have a fresh 427 SO, 4.250 bore, 9.8:1 compression, Comp 294S flat tappet (.605 lift), a set of new-out-of-the-box unworked medium riser heads, Erson roller rockers, Le Mans rotating assembly, Sidewinder intake and a 750 Mighty Demon and it made 451HP and 482 ft lbs of torque at the flywheel on a bonafide NHRA engine dyno. Plug that into your eap and tell me what it says. The software will claim much more.
these are the same specs the other guy has engine-wise, he has more compression, i used the same cam, same intake, same carb. looks like your numbers are inflated. i'll take the newer edelbrock aluminum heads over your unworked medium riser heads anyday.
