  #55 (permalink)
Old 12-07-2009, 03:01 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by elmariachi View Post
At the flywheel or rear wheels? How do you know?
Original flywheel dyno sheet from Danbury is 440 and 475 with no attempts at optimization, just a bolt-together of Joe L's standard 428 build.
I've replaced a boggy Holley with the Speed Demon and run the timing forward a step. While all my dialing in so far has been old-school, I eliminated the bog and it's a lot more responsive. Either the engine was down on power when I got it and I've restored it to original tune, or I've added a bit.
I plan to add some O2 bungs and do a sharper tuning job across the band before a dyno run and tune sometime in the spring.
= Si Opus Quadratum vis, angulos praecidere noli. =
