  #1131 (permalink)
Old 12-07-2009, 07:02 PM
capteddie's Avatar
capteddie capteddie is offline
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Great info!!! Thanks everybody!
I'll top the tank off this weekend when I'm back in town. Don't have a critter problem, so I'm ok there. I was thinking about getting the car up on jack stands on the Kwik Lift and taking the tires off all together, so I'll see how that works out. Need to do an antifreeze check. Not sure whats in the car now. I know its not straight H2O.
Thanks again!
Originally Posted by MotorcityCobra View Post
CaptEddie,
I agree with above about filling up the fuel tank to reduce the moisture then add the Stabil. Never had a problem, but maybe I never would have anyway.
Other things I've done in the past include:
Vapor barrier on cement under car
I use to up the tire pressure a bit, but I also parked it on heavy (dense) foam to try to distribute the load a bit (probably a waste of time, but made me feel better).
Obvious antifreeze check
I've heard of people scattering moth balls to help keep any varmits out, but I never had an issue with the little critters.
Regards,
MC
"the other ed"
