Hey all,
I was thinking of using a light to indicate when my ignition switch is on.
I would like to have this light on when the key is on but turn off when the motor is running.
I was thinking of using a relay turn on the light then taking a signal from the
oil pressure to have the light turn off. I am thinking when the pressure is above 5 psi it will then turn off the relay controling the light.
Is there a easier way of doing this?
