I am going to give it try. I found some 5.5oz carbon fabric on ebay and clear epoxy resin.
So far so good. I am sanding th dash down to get most off the gel coat as possible.
I prep the footbox cover. Covered it in epoxy and let it set up for 4 hours and while it was still tacky I layed fabric out on it. I did add a black pigment to the epoxy to the base coat.
Let dry 24 hrs and I just covered with a top coat. I used a heat gun to get the bubbles out and set for 24 hrs. Just put a seconded coat on after wet sanding.
I'll post finished picture tommorrow. On to the dash.
