Having a chat with myself:
So I gotta fit the body, to fit the hood,...etc......
I am concerned that a body being fit to a chassis without motor and trans in the car would fit one way, and if fit to the chassis with motor and trans in then it would fit another way. So do I really get concerned with this. My history tells me that I have fit doors and fenders to cars without motor and trans in, then things change once the motor is in and i have had to refit them even if only minor.
I am sure the body will assiist in stiffening up the frame, but I do not want the body to be carrying any more pressure than is really needed.
So maybe I will research how much the motor trans weigh, then place some boards across the frame to place weights equal to motor and place weight equal to trans on trans cross member. Then have tires and wheels installed and cars weight sitting on the tires. then fit the body to the chassis. This will allow me access room to adjust the hood. fit the doors, trunk lid should not matter in this case.
Then when body has been secured front to rear, I can remove weights, and install motor and trans. This might allow for neutral stress or pressure on frame and body as completed, and may not require readjustment of hood and doors upon final fit. but mainly I do not want stress on the body when car is finished and just sitting. There I am sure is enough torque and twisting during normal driving without continued stress.
So now I am listening to other little voices either within my head or outside to provide additional insights.
