  #77 (permalink)
Old 12-09-2009, 06:24 PM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default Check your motor mounts,
Originally Posted by twobjshelbys View Post
I also saw from this that the engine appears to be mounted slightly off level, I assume this was set up for a track. The drivers side side pipe is also rubbing on the body and now I'm starting to get a crack. Want to try to fix that soon.
Check your motor mounts they may have loosened up. Put a level across the motor. Valve cover to valve cover to check to see if its level. if its not it needs to be.
Morgan LeBlanc
Fresno CA
