UPdate: 124 hours, 19 days down, 71 to go;
Went parts chasing again and on the second stop I found the ignition switch that I would accept. My first stop was West marine, I thought that maybe they would have a pretty one. they only had expensive water proof ones that were not pretty.
I went to Vintage Ford, the local Ford restoration supply house. I purchased a 31 ford replacement ignition switch. Nut goes in from behind and leaves a nice clean front appearance and rather small and dainty looking. they did not have an acceptable push button starter. Stopped at Pep Boys and got that.
Then since we changed steering columns the custom work I did previously to improve the removeability had to be redone to fit the new column. You know changing things cost time and money. I think Kenton said, the most expensive thing about building these cars is changing your mind in mid stream.
Here is new steering column bracket again I can unbolt it from underneath very easily.
http://farm3.static.flickr.com/2713/...39e2a27d_b.jpg
Here is the ignition switch:
http://farm3.static.flickr.com/2507/...00e65225a4.jpg
Here is the steering column, I used the scrap left from the mustang column to fab up the bracket and fit it to the car. The opening in the dash is now much too large it will require fiberglassing it in to make it smaller. Also a good shot of the key. Nice neat and small.
http://farm3.static.flickr.com/2621/...714f2483_b.jpg
Hopefully, tomorrow will not require parts chasing and I can get a good days work in.
