Many times the speedo cable will leak where the input shaft housing is crimped to the cable by the speedo gear, it usually results in drips and not puddles but during removal and installation it may have made it more suspetible to leak.
Originally Posted by PANAVIA
are you SURE the leak is not the Speedo cable port / hole ->?
- as that will drip down and LOOK like the rear seal leaking.
Steve
