Old 12-10-2009, 05:58 PM
jwd's Avatar
jwd jwd is offline
Originally Posted by bobcowan View Post
Is there a groove in the output shaft? If so, you can install a repair sleeve to give the new seal a new surface to run against.
I assume you meant a groove on the driveshaft yolk since that is what the seal contacts. The most common cause of seal failure is a "dry install". Everything has to be pre-lubed or the seal will fail in a matter of seconds.
Jim
