  #28 (permalink)
Old 12-13-2009, 07:46 AM
Blittleton's Avatar
Blittleton Blittleton is offline
CC Member / Sponsor
Bill when you fitted the systems above, did you run into any problems with integrating the system with the standard EEC (A9L)? Or is that replaced completely? Second if one going to fit AFR or similar heads must that be done before fitting the Mass-Flo system?
Merv
The Mass Flo is a stand alone systems. It will be seperate from your chassis side. You can add the heads later if you wish, but it would be easier to do all at once. That will be up to you.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
