Old 12-14-2009, 06:37 PM
Rare Iron's Avatar
Rare Iron Rare Iron is offline
Originally Posted by vector1 View Post
hows this for rule of thumb
dual 2" = 216hp
dual 2.25" = 291hp
dual 3" = 533hp
dual 3.5" = 733hp
I would NEVER use 2" dual exhaust on ANY V-8! The pipe diameter is so small, it doesn't allow for proper expansion of the exhaust pulses & results in a lot of popping & backrapping. My rule of thumb is 2.5" up to 480 HP, beyond that you can go to dual 3" & not suffer any low or mid-range performance loss. A small block putting out under 350 HP run 2.25" or even 2.5". There is NOT a very big difference in scfm flow between 2.25" & 2.5". There is a quantium leap in scfm flow when transitioning from 2.5" to 3" exhaust. Keep in mind however, if you up the pipe diameter & run crappy-flowing mufflers, you defeat the whole purpose of the larger diameter. There are a lot of 3" in/out "performance" mufflers out there that flow like pigs! Beware!
The thing that blows my mind is most stock-type Cobra side exhaust mufflers have flowpaths under 2" in diameter. Imagine a fire-breathing big block in the 600+ HP range flowing through an exhaust passage as large as a Toyota Corolla exhaust system! How about a dual-core muffler? Looks like a regular tube muffler on the outside, but it has two staggered 1" flowpath cores on the inside. When you look inside these mufflers, there's a WALL immediately with a 1" entry into the first flow tube! Can you say 'jam a potato' in your tailpipe? Talk about turning your engine into a pump to get the exhaust out! MAJOR HP LOSS!
This was my inspiration!
