DV: Thanks again, I am puting on two down bars attached at about the same place I saw OFM's down bar attached. It will come up at a slight angle towards the middle of car which should provide some shear strength.
My measurements show 36 inches outside to outside and to start with 25 inches tall. I should have about 3 inches above the windshield with this size, I can cut some off as needed.
DV: Is there a reason the down legs have to move forward besides being able to be a nice place to run a bolt up thru frame to them.
My brackets are placed directly under the exit point of the body and then can be welded on the frame and then bar can be welded to the brackets is a person wants to. later tonite I will post pictures of the brackets.
Ray
