Old 12-16-2009, 07:48 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Bill Bess View Post
I agree with Patrick...take the damm thing off. In my entire life I never had a engine run right for very long with an automatic or maunal choke. If set up properly, they will work as designed, but you must know how to let them do their thing..don't keep pumping the pedal after it starts.
In 30 degree weather mine with no choke works great...starts right up....feather the throttle a bit until it idles and warms up ( about 2 -3 minutes).
I sort of regret going with a choke at all and may pull it off. It starts easier than I thought it would when really cold without using the choke and I don't mind feathering it for about 20 seconds and then letting it idle for a bit, so I'm not seeing much benefit. But I will probably still play around with it a bit more before I make the decision.
www.partskeeper.com
