Thread: Garage space?
Old 12-17-2009, 06:48 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I have not done it, but I am sure it can be done. Make use of the walls and wasted are between the garage door rails and the wall for storage.
Keep everything in boxes and do not remove items that you will not need til the end.
Plan your project out carefully and you should be fine.
However, if it rains or snows it then becomes difficult to move around with the door close.
Good luck
