Old 12-18-2009, 03:59 AM
Default Did you use a fuel stablizer?
Bernica If you used stablizer I would still remove all the fuel and put 15-20 gallons of new in the car and add about 2-2.5 gallons of the old stuff and use it up. You could also do the same thing with adding it to the daily driver until used up. I would only use a gallon in the daily driver. I have left gas in the car for a year and still have it run. It does smell bad. The other thing is to just go to a recycling center with the old gas and let them get rid of it. Soneone will fill there tank with it for sure. Rick L. If the car is going to sit for more than 3 months, add stablizer, keeps the gas fresh. Rick L.
