Thread: Era/spf/csx
  #74 (permalink)
Old 12-18-2009, 12:19 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Chapter 5 - Familiarizing Yourself With The Dashboard Prior to First Drive - Now this can be a crucial entry in the manual. Do NOT take your new car out on its maiden voyage without first studying all gauges, knobs and/or switches. If you do NOT follow this step, don't ask yourself "I wonder what this switch does?", switching on and off toggle switches, testing indiscriminately each switch, while car is in operation. This includes the most important switch, the FUEL PUMP switch. The position of the FUEL PUMP switch should be a dead giveaway, since it is DIRECTLY located below the fuel pressure gauge. This switch will shut off all gas to car and slow car down immediately. If said switch is toggled off, then IMMEDIATELY TOGGLE SWITCH BACK ON before you get yourself into an accident.
