Hey all,
I was letting my car idle in my drive way when I heard a click sound. I decided to pull the valve cover and a rocker arm fell out.
Now, I am running a low lash camshaft with lash set to .008 which is within spec of the cam card. I have verified this several times and the card is correct.
Now, my only thoughts is that since it is cold here in FL (temp 67 degrees) tha the lash was too tight.
I am running aluminum heads with iron block.
What are your thoughts
