As everyone has said.....a mild motor. If you are going thru with the expense of stroking you should bump up your top end. I have a 408 with afr 205 heads,, cam with .600 lift duration in the 250ish, vic jr intake with 850dblpmpr. I dyno'd at 437hp at the rear wheels corrected at the flywheel 555hp. If you want a mild cobra stick with a 351 and save yourself the bucks . Not a slam by any means just giving you my2 cents. Berm
