Originally Posted by madmaxx
Use a plastic putty knife or you will scratch the aluminium center on the steering wheel. Do not use a screwdriver!!!!!!!The best way is to get you some 15lb fishing line and wrap around the center cap once it slides under just pop it off.
I would also like to know the answer to your question, can we just use the insert or do we need the whole cap, does anyone know.
From another post on here I ended up using the plastic tools made for bicycle tire removal which worked well and leave no scratches.
I think I was trying to find the difference between the $60 cap vs the $30 insert.
Jim48, which one did you buy?
Thanks
