Hi
what are the alternatives to using an old FE expansion tank to connect my rad to my intake?? I have a 428 with the edelbrock RPM manifold
Fe tanks seem to be expensive unless I can find one at the wrecker...
I would like to know what is out there aftermarket or what guys have used for the job. I have seen a picture where a moroso style Tee was piped between the two openings with rad hose of corresponding sizes.
Am I correct in assuming the Tee with it's rad cap has to be the highest point in the system?? ( airlocks and filling point)
Also am I correct in saying that there is no pressure at this point.
If I make something up here is this also where the line for the puke tank originates??
So is the moroso tank meant to be a puke/catch can from the TEE or double as an expansion tank??
Love to see photos if you guys have any.
Thanks
Tim
