  #45 (permalink)
Old 12-25-2009, 06:35 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
when i was building my ffr i built a 342 stroker i had already had the ford motorsport efi harness all the sensors and a 93 computer (A3M1), i was going to use the ford cobra intake and i already had a msd tfi distributor so i was at chris's (quality roadsters) before he started mass flo fuel inj and he showed me his new set up but i was able just to buy a intake with rails a t body, a mass air meter, and the little harness adapter that converts the (gm signal) to the ford voltage reading. and i was all set, the only thing is depending on your engine set up you may need a chip so your set up will run ok . you can also buy the moates quarter horse and tune it your self with a laptop, or go to a dyno tuner and get a chip burned.
you can check out eectuning.org to learn about tuning with the tweecer rt or the new moates quarter horse they plug in to the service port and connects to a laptop with a usb cable.
