Old 12-31-2009, 05:53 PM
jhv48 jhv48 is offline
Well, you asked. SPF 2932.
1. Leaking intake manifold gasket, Installer fixed it.
2. Front wheels out of balance, one wheel slightly out of round. Had to have the fronts balanced on the car to fix it.
3. Leaking oil pressure line. I fixed it.
4. Horn not connected. I fixed it.
5. Stuck thermostat. Installer fixed it.
6. Blown sidepipe gaskets. I fixed them.
7. Oil temp gauge stopped working. I replaced it.
8. Side mirror loose. Installer fixed it.
9. Speedo cable jumps. Greased cable, slowed it down a bit.
10.Rear tires rubbing on wheel well. I adjusted the ride height.
So far, in four months, this is all the little things that I have had to deal with. Just a part of the ownership experience I guess. I went through the same things with my last Cobra. That's half of the fun of owning one of these cars.
Getting them sorted out.
Jim
