Originally Posted by jhv48
3. Leaking oil pressure line. I fixed it.
I had the same problem with the leaking oil pressure line. I ended up changing the nylon hose to an AN line (base on a recommendation from a fellow owner). Completely resolved all leaks at the block.
Here's a link to all of the pieces that you'll need to replace the line.
Best way to access back of oil pressure gauge
Doug
